Форум Picbasic.ru » Программирование МК » Mikrobasic » Профессиональный Микробасик
MasterPic Дата: Вт, 24.03.2009, 07:17  |        Сообщение # 1
Репутация: 2   ±
На сайте с 22.11.2008
Доступен для скачивания здесь. Может, к нам на сайт залить?
Вот основные особенности:
Quote
- New: Customizable new look
- New: Layout manager
- New: Project manager
- New: Library manager
- New: Drag and drop files to editor
- New: Code folding feature
- New: Autocorrect notification
- New: Declaration syntax checker
- New: Advanced bookmark editor
- New: Macro manager
- New: New project wizard
- New: Import Project
- New: Bug report tool
- New: Templates for AutoComplete
- New: Complete Help for IDE + Language and library reference and PIC specifics
- New: Spell checker
- Improved: Brackets painter
- Improved: Code explorer
- Improved: Docking manager
- Improved: Messages window with filtering
- Improved: Grep search feature
- Improved: Code Assistant, Parameter Assistant
- Improved: Edit project
- Compiler
- Additional chips supported:
P16F722 P16LF722 P18C242 P18C658
P16F723 P16LF723 P18C252 P18C801
P16F724 P16LF724 P18C442 P18C858
P16F726 P16LF726 P18C452
P16F727 P16LF727 P18C601
- New: Command line interface
- New: Bit, sbit variables support
- New: Additional set of keywords to fasciliate PIC programming:
code sbit
data bit
sfr rx
at
- New: OrgAll pragma added
- New: PrintOut library added
- New: Efficient file format for libraries (.MCL)
- New: definition files with bit definitions included
- New: mlk files improved (XML file type)
- New: Compiler front end redesigned for faster compilation
- New: Remapping local varibales to working register optimization
- New: Propagation of indirect objects
- New: MultipAss allocation of functions
- New: PeepHole optimisation added to Linker
- New: Compress call optimisation added to Linker
- Improved: Libraries rewritten to take advantage of new sbit and bit type (smaller and faster code)
- Improved: pointer to functions added to libraries (SPI, UART) P18 family
- Improved: Greater flexibility for libraries which use SPI, UART modules (SPI_Glcd, MMC, Ethernet, RS485 etc.) P18 family
- Improved: Optimizer rewritten
- Improved: Handling of indirectly called functions
- Improved: propagation algorithm
- Improved: Smart interrupt context saving
- Improved: inline assembler
- Improved: memory banks handling linker algorithm
- Improved: Fast and efficient linker algorithm
- Improved: Fast Hex generator
- Improved: Fast loading and writing compiled libraries (.MCL)
- Improved: Messaging system
- Improved: Output options control
- Improved: Libraries redesigned and rewritten to meet demands of PIC architecture
- Improved: Fast and small executable code
- Improved: Reported bugs fixed
ЯНДЕКС Дата: 24.03.2009
vladh Дата: Ср, 25.03.2009, 10:52  |        Сообщение # 2
На сайте с 15.10.2007
Какой же это профессиональный? Это самый настоящий любительский. Создаёт hex-файл только до 2 к. Вот профессиональный
http://rl-team.net/warez....k.html. Но тоже говорят не очень хорошо опрофессионалили.
